21K views 20 replies 14 participants last post by  HeavyMetal4Ever
#1 ·
What FX pedal do you think is the best for playing metal solos without getting to "fake-tone" sounding if that makes sense?
#7 ·
Hmm... perhaps I'm going to make a sweeping judgment here, but nonetheless I base it on (a lot of) personal experience.
I would avoid ANY distortion pedal which is labelled "Metal". I have tried many, such as the aforementioned Boss Metal Zone and its Digitech equivelant, plus a variety of other distortion pedals which are labelled "Metal" and, to my ears, they ALL shared one common denominator; they all sounded like utter garbage. Horrible, tinny, noisey, and absolutely NO chance of being heard on stage or in a studio in a mix.
Best way is to set your amp up to get a "Metal" sound. What amp are you using? In most cases plenty of Gain, Lots of bass and treble and a little mids will get you a decent metal rhythm sound. Don't take out too much middle or you'll never be heard in the mix if you're playing in a band. And use an EQ pedal to add mids for a lead break... ;)
'87
P.S. Other distortion/overdrive pedals may be of use however... just avoid anything labelled "Metal" because it is bound to sound garbage.
#9 ·
I'll second the overdrive idea with your current distortion on your amp (TS-9, Xotic, ect).
On a side note, I tried the new Boss Metal Core and was impressed thru a Mesa F-50 and a Fender Hot Rod Deluxe (both set to clean of course). I'm NOT a fan of the Metal Zone but the Metal Core does have potential IMHO.
#10 ·
I would try an EQ pedal first (boost the mids as mentioned previously, maybe highs too), if that fails try some overdrive pedal like Digitech Bad Monkey, and only as an absolutely last resort buy a distortion pedal. You have a nice amp, using a pedal to distort the signal before it gets to the amp would be a shame.
#17 ·
You might be onto something. I just found a clip of a guy using a EQ in the loop and making his F-30 1x12 combo into a half stack sound like a recto. I think I will try that. Any good eq pedals besides Boss and MXR?
#12 ·
It doesn't even matter. If you already have some drive and want something over the top get any decently high gain distortion pedal and play with it. If you have an ear for what you want you can dial in the sound.
I used to have the dreaded Boss Metal Zone and when setup up just right and in the right context. I could kick that sucker on and get insanely hot heavy molten in your face, tone dripping, face melting solos. It could also sound like crap depending on how the amp, pedal, guitar, and other pedals were setup. I'm talking live band situation not bedroom level which is a whole nother deal.
